Ana içeriğe geç
Toshiba Satellite C55D-C5106 RAM Replacement
Laura Tamayo
Laura Tamayo ve başka bir katkıda bulunan
En son December 15, 2022 tarihinde güncellendi
10 dakika
Kolay
In the case you need to replace the RAM of your Toshiba Satellite C55D-C5106, this guide will show you the steps on how to perform the task.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite C55D-C5106 RAM Replacement, RAM: adım 1, 3 resimden 1. Toshiba Satellite C55D-C5106 RAM Replacement, RAM: adım 1, 3 resimden 2. Toshiba Satellite C55D-C5106 RAM Replacement, RAM: adım 1, 3 resimden 3.
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 RAM Replacement: adım 2, 1 resimden 1.
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 RAM Replacement: adım 3, 1 resimden 1.
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
  4. Toshiba Satellite C55D-C5106 RAM Replacement: adım 4, 3 resimden 1. Toshiba Satellite C55D-C5106 RAM Replacement: adım 4, 3 resimden 2. Toshiba Satellite C55D-C5106 RAM Replacement: adım 4, 3 resimden 3.
    • Use the metal spudger to remove the bottom cover of the laptop.
  5. Toshiba Satellite C55D-C5106 RAM Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55D-C5106 RAM Replacement: adım 5, 2 resimden 2.
    • Pull out the clips securing the RAM chip.
    • Remove the RAM chip.
Sonuç
Laura Tamayo
678 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2019 USF Tampa, Team S1-G4, Leahy Spring 2019 üyesi
USFT-LEAHY-S19S1G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 365
