Ana içeriğe geç
Toshiba Satellite C55Dt-A5306 Disc Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Place fingers on the latches and slide outwards to unlock.
  2. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: adım 2, 1 resimden 1.
    • Remove battery.
  3. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Back Cover: adım 3, 1 resimden 1.
    • Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
  4. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: adım 4, 1 resimden 1.
    • Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
  5. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: adım 5, 1 resimden 1.
    • Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
  6. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement: adım 6, 2 resimden 2.
    • Using the plastic spudger, pry the back off along the periphery of the laptop.
  7. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: adım 7, 2 resimden 1. Toshiba Satellite C55Dt-A5306 Disc Drive Replacement, Disc Drive: adım 7, 2 resimden 2.
    • Slide the disc drive to the left. It should come off with ease.
Sonuç
zeena qiryaqoz
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Bir Yorum
Change the title to say "optical drive," rather than "disc drive." I was fooled while looking for instructions on removing the hard drive.
ed_l_grey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 463
