Ana içeriğe geç
Toshiba Satellite C655-S5142 Keyboard Replacement
Alex Kozlowski
Alex Kozlowski ve 5 diğer katkıda bulunanlar
En son February 16, 2025 tarihinde güncellendi
3 - 5 dakika
Orta
Madde imleri!
Daha İyi Resimler Gerekli
Daha iyi giriş
Öğrenci İş Başında
If the keyboard of your Toshiba Satellite C655-S5142 isn't responding to attempts to type, this guide will help you to properly replace the previous components. If your keyboard is faulty, then it's likely that one key or multiple keys are no longer functioning as intended. Before you start the replacement, check to see if cleaning out the sensors by using a flathead screwdriver to gently pry up the keys, then dusting the keys using a dust blower or safe brush, before deciding to replace the keyboard itself. It may just need to be cleaned in order to function properly. Try to type a sentence or two using the faulty keys in order to make sure it's not resolved.
This is a sensitive part of the computer, so try to keep your area clean of food or dust while you work. If crumbs or dust get inside of the laptop's sensors, it may not function properly, even after replacing it.
Before beginning, ensure the laptop itself is turned off and disconnected from any external power source, such as a charger or hard drive.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Using the metal spudger, gently insert it under the plastic covering slowly easing it up until the screws are revealed.
    • The plastic covering will make clicking sounds when being removed this is normal, you are not breaking it.
  2. Toshiba Satellite C655-S5142 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite C655-S5142 Keyboard Replacement: adım 2, 2 resimden 2.
    • Using a phillips head screwdriver, unscrew each of the four screws.
  3. Toshiba Satellite C655-S5142 Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite C655-S5142 Keyboard Replacement: adım 3, 2 resimden 2.
    • Gradually lift the keyboard up, it will reveal the connector cable.
    • Do not pull the keyboard away too hard, this may damage the connector.
  4. Toshiba Satellite C655-S5142 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite C655-S5142 Keyboard Replacement: adım 4, 2 resimden 2.
    • With the keyboard resting up, pull the tabs to disconnect the cable from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Kozlowski
244 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 409
