Ana içeriğe geç
Toshiba Satellite C855-S5115 CMOS Battery Replacement
Claire Fletcher
Claire Fletcher ve 2 diğer katkıda bulunanlar
En son December 29, 2022 tarihinde güncellendi
5 dakika
Kolay
You might need to replace your CMOS (Complementary Metal Oxide Semiconductor) battery if your Toshiba laptop is losing its time and date settings or if you are receiving a CMOS error message. You will also need to remove your CMOS before replacing other elements, such as the motherboard.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite C855-S5115 CMOS Battery Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C855-S5115 CMOS Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 CMOS Battery Replacement: adım 2, 1 resimden 1.
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 CMOS Battery Replacement, CMOS Battery: adım 3, 1 resimden 1.
    • Remove the 7mm screw from the back panel using the Phillips head screwdriver.
  4. Toshiba Satellite C855-S5115 CMOS Battery Replacement: adım 4, 2 resimden 1. Toshiba Satellite C855-S5115 CMOS Battery Replacement: adım 4, 2 resimden 2.
    • Use the spudger to pry the back panel out of the laptop.
  5. Toshiba Satellite C855-S5115 CMOS Battery Replacement: adım 5, 2 resimden 1. Toshiba Satellite C855-S5115 CMOS Battery Replacement: adım 5, 2 resimden 2.
    • Push the pin that holds the CMOS battery in place downwards. The battery will then come out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 70
Her zaman: 5,411
