Ana içeriğe geç
Toshiba Satellite C855D-S5303 Battery Replacement
  1. Toshiba Satellite C855D-S5303 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Lay your laptop upside down on a flat surface.
    • Power off your laptop and unplug the charger.
    • Make sure you allow the laptop time to cool so that you aren't removing a hot battery.
  2. Toshiba Satellite C855D-S5303 Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite C855D-S5303 Battery Replacement: adım 2, 2 resimden 2.
    • Locate the right eject switch, labeled "1".
    • Slide the switch all the way to the right and it should stay in place.
  3. Toshiba Satellite C855D-S5303 Battery Replacement: adım 3, 1 resimden 1.
    • The second eject switch is on the left and it is numbered "2".
    • Slide the switch to the left and remain pushing on it, because unlike switch "1" it will not stay in place on it's own.
  4. Toshiba Satellite C855D-S5303 Battery Replacement: adım 4, 2 resimden 1. Toshiba Satellite C855D-S5303 Battery Replacement: adım 4, 2 resimden 2.
    • With hand still pushing the left switch, grab onto notch at the center of the two switches.
    • Pull up and towards you. The battery will begin to lift out of the device.
  5. Toshiba Satellite C855D-S5303 Battery Replacement: adım 5, 1 resimden 1.
    • The battery can now be pulled out entirely. You are ready to replace it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Courtney Burns
863 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 UMass Dartmouth, Team 2-5, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G5
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
It appears likely that these batteries are NICAD type. And NiCad batteries CAN be reprogrammed to accept charge.
Is that possible with these Toshiba units?
Rick Walker - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 1,068
