Toshiba Satellite C855D-S5303 Disc Drive Replacement
Giriş
1. adıma gitThis guide will show you how to replace your disc drive. This repair requires only a small Phillips Head Screwdriver and your hands.
Neye ihtiyacın var
To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
Bir başkası bu kılavuzu tamamladı.
