Ana içeriğe geç
Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement
Neye ihtiyacın var
  1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom of the device is facing upward.
  2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 2, 1 resimden 1.
    • Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
  3. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 3, 1 resimden 1.
    • Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
    • Be careful not to bend or crack the plastic back cover.
  4. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
  5. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 5, 1 resimden 1.
    • Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
  6. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 6, 1 resimden 1.
    • Carefully unplug the battery from the device motherboard.
  7. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: adım 7, 3 resimden 1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: adım 7, 3 resimden 2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement, Screen Display Assembly: adım 7, 3 resimden 3.
    • Unplug the power connector by pulling back the tape and sliding the connector away using the blue opening tool.
  8. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 8, 3 resimden 1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 8, 3 resimden 2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the foam and unplug the black and white coaxial cables to the network card by pulling upward using the black tweezers.
  9. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 9, 2 resimden 1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 9, 2 resimden 2.
    • Remove the black webcam connector by pulling backwards with the tweezers.
  10. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 10, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove four 5.00 mm screws from both corner hinges of the display assembly.
  11. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 11, 3 resimden 1. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 11, 3 resimden 2. Toshiba Satellite CL15t-B1204X Screen Display Assembly Replacement: adım 11, 3 resimden 3.
    • Open the laptop and remove the display assembly from the keyboard assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Hook
439 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G6, Hovde Fall 2019 IUPUI, Team S1-G6, Hovde Fall 2019 üyesi
IUPUI-HOVDE-F19S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 309
