Ana içeriğe geç
Toshiba Satellite Click 2 Pro Motherboard Replacement
Paul DeOrsey
Paul DeOrsey ve 3 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
20 dakika
Orta
To attempt this guide, make sure to have all required materials and tools. This guide is the longest and most difficult of all the guides. Requires your full attention in to properly replace it.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite Click 2 Pro Motherboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite Click 2 Pro Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 2, 3 resimden 1. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 2, 3 resimden 2. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 5, 3 resimden 1. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 5, 3 resimden 2. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 5, 3 resimden 3.
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Motherboard Replacement, Heat Sync Fan: adım 8, 1 resimden 1.
    • Remove the power connector from the fan using a pair of tweezers.
  9. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove two 3.0mm Phillips J0 screws using a Phillips screw driver.
  10. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove four 3.5mm Phillips J0 screws from the heat sink.
  11. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the heat sink fan.
    • The heat sink cover may be hard to peel off the first time due to the adhesive.
  12. Toshiba Satellite Click 2 Pro Motherboard Replacement, Wifi Card: adım 12, 1 resimden 1.
    • Remove the 3mm screw J0 Phillips screw with the Philips screw driver.
  13. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 13, 1 resimden 1.
    • Remove the black and white cables attached using ESD safe tweezers.
  14. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove wifi card.
  15. Toshiba Satellite Click 2 Pro Motherboard Replacement, Motherboard: adım 15, 1 resimden 1.
    • Locate and remove the five connectors using ESD safe tweezers.
  16. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 16, 2 resimden 1. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 16, 2 resimden 2.
    • Remove the four 3.0mm Phillips J0 screws using a Phillips screw driver.
  17. Toshiba Satellite Click 2 Pro Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Paul DeOrsey
893 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-3, Catania Spring 2016 UMass Dartmouth, Team 4-3, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,262
