Ana içeriğe geç
Toshiba Satellite E45t-B4204 Keyboard  Replacement
Youdong Yan
Youdong Yan ve 5 diğer katkıda bulunanlar
En son January 21, 2025 tarihinde güncellendi
1 saat
Zor
Daha İyi Resimler Gerekli
İşlem Görüntüleri
Tutarsız Görseller
Madde imleri!
Manzaralı Yol
Metin kafa karıştırıcı
Hatalı İşaretlenmiş
Daha Fazla Görsel Gerekli
Eksik Adımlar
This guide will explain the process of removing the keyboard in the Toshiba Satellite E45t-B4204. Keyboard removal requires nearly all major components being removed to
Neye ihtiyacın var
Aletler
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: adım 1, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: adım 1, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Back Case: adım 1, 3 resimden 3.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 2, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 2, 2 resimden 2.
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 3, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 3, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 3, 3 resimden 3.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: adım 4, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement, Keyboard: adım 4, 2 resimden 2.
    • Remove speaker by unscrewing the 4 screws at the side of the speaker with the Phillips #1 screwdriver.
  5. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 5, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 5, 2 resimden 2.
    • Unplug speaker wires from the motherboard using a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photo could potentially damage your device.
    • Remove speakers.
  6. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 6, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 6, 2 resimden 2.
    • Unscrew 6 screws from the chassis with the Phillips #1 screwdriver.
  7. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 7, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 7, 2 resimden 2.
    • Unscrew 8 screws from the motherboard using the Phillips #1 screwdriver.
  8. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 8, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 8, 2 resimden 2.
    • Unplug wire from the motherboard.
  9. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 9, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 9, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 9, 3 resimden 3.
    • Unscrew screws from the motherboard using the Phillips #1 screwdriver.
  10. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 10, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 10, 2 resimden 2.
    • Unscrew screws from the CPU heat sink using the Phillips #1 screwdriver.
  11. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 11, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 11, 2 resimden 2.
    • Unplug the wire from the motherboard.
    • Remove the heat sink.
  12. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 12, 2 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 12, 2 resimden 2.
    • Remove the CPU.
  13. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 13, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 13, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 13, 3 resimden 3.
    • Unscrew the motherboard with the Phillips #1 screwdriver.
  14. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 14, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 14, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 14, 3 resimden 3.
    • Remove the motherboard.
  15. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 15, 3 resimden 1. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 15, 3 resimden 2. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 15, 3 resimden 3.
    • Unscrew the keyboard cover using the Phillips #0 screwdriver.
    • Unscrew the keyboard cover using the #1 screwdriver.
  16. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 16, 1 resimden 1.
    • Remove the keyboard cover.
  17. Toshiba Satellite E45t-B4204 Keyboard  Replacement: adım 17, 1 resimden 1.
    • Remove the keyboard.
Sonuç
Youdong Yan
229 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Wilson Summer 2019 IUPUI, Team S3-G3, Wilson Summer 2019 üyesi
IUPUI-WILSON-SU19S3G3
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Do you know where in this process the webcam is connected/disconnected? I just completed this process to replace the keyboard and swap in a new SSD while I had everything opened up. I got everything closed back up, and it's all running great, but just noticed that the computer no longer recognizes that there is a webcam. I would swear I plugged in everything that I had unplugged, but I can't figure out where the webcam connection might be.
Brent Murphy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 613
