Ana içeriğe geç
Toshiba Satellite E45t-B4204 Thermal Paste Replacement
Eduardo
Eduardo ve 6 diğer katkıda bulunanlar
En son March 29, 2024 tarihinde güncellendi
1 saat
Zor
Daha İyi Resimler Gerekli
This will be a quick guide on how to replace the thermal paste of a Toshiba Satellite E45t-B4204. Replacing the thermal paste will help transfer the heat from the CPU to the heatsink and out of the laptop.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: adım 1, 3 resimden 1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: adım 1, 3 resimden 2. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Back Case: adım 1, 3 resimden 3.
    • Remove all 14 of the 4 mm screws on the back side of the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: adım 2, 2 resimden 1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: adım 2, 2 resimden 2.
    • Gently pull out the battery.
  3. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: adım 3, 3 resimden 1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: adım 3, 3 resimden 2. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: adım 3, 3 resimden 3.
    • Lift up in the spaces left by the battery to create a gap between the back case and the laptop body.
    • Run a spudger along both sides of the laptop to widen the separation and release the clips holding the back case on.
    • Remove the back case.
  4. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: adım 4, 2 resimden 1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement, Thermal Paste: adım 4, 2 resimden 2.
    • Locate and remove the four 3 mm screws around the CPU.
    • The CPU is located beneath the copper heatsink.
  5. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: adım 5, 2 resimden 1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: adım 5, 2 resimden 2.
    • Carefully remove the heatsink from the rest of the motherboard and casing.
  6. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: adım 6, 2 resimden 1. Toshiba Satellite E45t-B4204 Thermal Paste Replacement: adım 6, 2 resimden 2.
    • Now that the heatsink has been removed the CPU is visible. The CPU is the green square with silver metal in the center.
    • Reapply thermal paste above the CPU.
Sonuç
Eduardo
411 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 523
