Ana içeriğe geç
Toshiba Satellite L15W-B1320 Hard Drive Replacement
Elizabeth Zapata
Elizabeth Zapata ve 2 diğer katkıda bulunanlar
En son January 18, 2023 tarihinde güncellendi
5 - 10 dakika
Kolay
The hard drive may need replacement due to a variety of reasons such as malfunction, overuse, etc. This guide will demonstrate how to find, and remove the laptop's hard drive in order for replacement.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Close the laptop and flip it over so that the base is facing upward.
    • Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
    • Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
  2. Toshiba Satellite L15W-B1320 Hard Drive Replacement: adım 2, 3 resimden 1. Toshiba Satellite L15W-B1320 Hard Drive Replacement: adım 2, 3 resimden 2. Toshiba Satellite L15W-B1320 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
    • Disconnect the indicated cable from the cable connector by gently pulling on it.
    • Lift up the battery carefully.
  3. Toshiba Satellite L15W-B1320 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • The hard drive is connected at the end of the white barcode.
    • To remove, first pull up on the end of the hard drive opposite of the barcode.
  4. Toshiba Satellite L15W-B1320 Hard Drive Replacement: adım 4, 1 resimden 1.
    • After pulling up on the hard drive, pull in the opposite of the direction of the white barcode.
Sonuç
Elizabeth Zapata
190 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Excelente tutorial... más especifico no podría ser
Muchas gracias por compartir el conocimiento..
Luis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 1,375
