Ana içeriğe geç
Toshiba Satellite L45-S7423 Bottom Access Panel Replacement
Stephen Sippel
Stephen Sippel ve 4 diğer katkıda bulunanlar
En son June 14, 2023 tarihinde güncellendi
5 dakika
Kolay
Öne Çıkan Öğrenci Kılavuzu
The bottom access panel is designed to be quickly and easily removed to allow the consumer quick access to components of the the computer including RAM, the wireless card, and the dial up modem. This panel requires only the the removal of a five screws to gain the user access.
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement: adım 2, 2 resimden 1. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement: adım 3, 2 resimden 1. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement: adım 3, 2 resimden 2.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement, Bottom Access Panel: adım 4, 3 resimden 1. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement, Bottom Access Panel: adım 4, 3 resimden 2. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement, Bottom Access Panel: adım 4, 3 resimden 3.
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement: adım 5, 3 resimden 1. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement: adım 5, 3 resimden 2. Toshiba Satellite L45-S7423 Bottom Access Panel Replacement: adım 5, 3 resimden 3.
    • Use a finger to remove the panel by lifting up on the provided removal tab.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Stephen Sippel
194 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G54
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 927
