Toshiba Satellite L45-S7423 Keyboard Replacement
Giriş
1. adıma gitThe keyboard is subject to some of the most abuse experienced by a laptop. Whether it is from over use or even water damage, the keyboard can stop working. With the removal a couple screws and the release of a few tabs, the keyboard can be replaced with little effort.
Neye ihtiyacın var
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Remove the two screws holding the keyboard in place.
Two 5.7 mm Phillips screws.
3 farklı kişi bu kılavuzu tamamladı.
