Ana içeriğe geç
Toshiba Satellite L45-S7423 Optical Drive Replacement
Stephen Sippel
Stephen Sippel ve 4 diğer katkıda bulunanlar
En son June 14, 2023 tarihinde güncellendi
5 - 10 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
The optical drive reads the CD/DVD when inserted into the laptop. It is not unusual for the optical drive to go stop working or malfunction as there are numerous moving parts. This device is designed to be easily replaced in the case it does malfunction.
Neye ihtiyacın var
Aletler
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 3, 2 resimden 2.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: adım 4, 3 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: adım 4, 3 resimden 2. Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: adım 4, 3 resimden 3.
    • Remove the two screws holding the hard drive panel down.
    • These screw are permanently fastened to the panel; they are designed to be removed only partially.
  5. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 5, 1 resimden 1.
    • Use a finger to lift up on the tab and remove the panel.
  6. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 6, 2 resimden 2.
    • Remove the screw that holds in place the optical drive.
    • One 4.6 mm Phillips screw.
  7. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 7, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 7, 2 resimden 2.
    • Locate the small rectangular hole and insert the spudger.
    • Gently slide the metal flange to the right to dislodge the optical drive.
  8. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 8, 1 resimden 1.
    • The optical drive will become partially exposed.
  9. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 9, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 9, 2 resimden 2.
    • Pull the optical drive to remove it from the computer body.
Sonuç
Stephen Sippel
194 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G54
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 920
