Toshiba Satellite L505D-GS6000 Battery Replacement
Giriş
1. adıma gitThis guide will show you how to replace your battery.
You may need to replace your battery if you notice your computer dying after short periods of use.
Replacing your battery is a short and easy process that should require no tools to complete.
Neye ihtiyacın var
Flip the computer over so that the bottom is facing up.
Slide right switch above the battery so that it is in the rightwards position.
