Ana içeriğe geç
Toshiba Satellite L55t-B5271 Screen Replacement
Carson Longendorfer
Carson Longendorfer ve 3 diğer katkıda bulunanlar
En son May 21, 2018 tarihinde güncellendi
25 - 30 dakika
Zor
This guide will assist you in removing the display of your device. You'll need to be extra careful when removing the glass screen from your device.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite L55t-B5271 Screen Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L55t-B5271 Screen Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L55t-B5271 Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Screen Replacement: adım 2, 2 resimden 1. Toshiba Satellite L55t-B5271 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Screen Replacement: adım 3, 3 resimden 1. Toshiba Satellite L55t-B5271 Screen Replacement: adım 3, 3 resimden 2. Toshiba Satellite L55t-B5271 Screen Replacement: adım 3, 3 resimden 3.
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: adım 4, 3 resimden 1. Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: adım 4, 3 resimden 2. Toshiba Satellite L55t-B5271 Screen Replacement, Back Panel: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Screen Replacement, Screen: adım 5, 3 resimden 1. Toshiba Satellite L55t-B5271 Screen Replacement, Screen: adım 5, 3 resimden 2. Toshiba Satellite L55t-B5271 Screen Replacement, Screen: adım 5, 3 resimden 3.
    • Unscrew the four 6mm screws from each of the laptop hinges using a Philips head #00 screwdriver.
  6. Toshiba Satellite L55t-B5271 Screen Replacement: adım 6, 3 resimden 1. Toshiba Satellite L55t-B5271 Screen Replacement: adım 6, 3 resimden 2. Toshiba Satellite L55t-B5271 Screen Replacement: adım 6, 3 resimden 3.
    • Disconnect connect the ribbon marked in red.
    • Disconnect all ribbons and cables marked in orange.
  7. Toshiba Satellite L55t-B5271 Screen Replacement: adım 7, 1 resimden 1.
    • Flip your laptop back to the front.
    • Lift up the screen cover.
  8. Toshiba Satellite L55t-B5271 Screen Replacement: adım 8, 2 resimden 1. Toshiba Satellite L55t-B5271 Screen Replacement: adım 8, 2 resimden 2.
    • Gently pull the screen to disconnect the monitor from the hinges.
  9. Toshiba Satellite L55t-B5271 Screen Replacement: adım 9, 3 resimden 1. Toshiba Satellite L55t-B5271 Screen Replacement: adım 9, 3 resimden 2. Toshiba Satellite L55t-B5271 Screen Replacement: adım 9, 3 resimden 3.
    • Use the plastic opening tool to pry the plastic covering off of the monitor.
    • Be careful not to break the glass, as this can cause injury.
  10. Toshiba Satellite L55t-B5271 Screen Replacement: adım 10, 3 resimden 1. Toshiba Satellite L55t-B5271 Screen Replacement: adım 10, 3 resimden 2. Toshiba Satellite L55t-B5271 Screen Replacement: adım 10, 3 resimden 3.
    • Remove the four 3mm Phillips head screws with a Phillips #00 screwdriver.
    • Gently remove the screen from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Carson Longendorfer
274 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,478
