Ana içeriğe geç
Toshiba Satellite L655D-S5095 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Keyboard Replacement: adım 2, 1 resimden 1.
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Keyboard Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite L655D-S5095 Keyboard Replacement: adım 5, 2 resimden 2.
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Keyboard Replacement: adım 6, 1 resimden 1.
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Keyboard Replacement: adım 7, 1 resimden 1.
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jerry Wakai
377 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G7
5 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Christopher Tidwell - Yanıt
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
salirizz67@gmail.com -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 5,025
