Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Toshiba Satellite L775D-S7340 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L775D-S7340 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Keyboard Replacement: adım 3, 1 resimden 1.
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Toshiba Satellite L775D-S7340 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
    These screws are Phillips, not Torx T4.
    John Beekman - Yanıt
  6. Toshiba Satellite L775D-S7340 Keyboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite L775D-S7340 Keyboard Replacement: adım 6, 2 resimden 2.
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. Toshiba Satellite L775D-S7340 Keyboard Replacement: adım 7, 1 resimden 1.
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Madeline Park
441 İtibar
4 adet Kılavuz yazıldı
Ekip
Bir Yorum
I need to know how to change a plasma for a Toshiba Satellite L775D-S7340
Cyndi May Evans - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 1,703
