Ana içeriğe geç
Toshiba Satellite L855-S5119 Laptop Screen Replacement
Monte Roden
Monte Roden ve 4 diğer katkıda bulunanlar
En son June 11, 2023 tarihinde güncellendi
15 - 20 dakika
Zor
This guide will inform readers on how to replace the screen which may stop working.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Plate Removal: adım 1, 3 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Plate Removal: adım 1, 3 resimden 2. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Plate Removal: adım 1, 3 resimden 3.
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  2. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Battery: adım 2, 1 resimden 1.
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  3. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 3, 3 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 3, 3 resimden 2. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 3, 3 resimden 3.
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  4. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 4, 2 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 4, 2 resimden 2.
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  5. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Optical Drive: adım 5, 2 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Optical Drive: adım 5, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  6. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 6, 2 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 6, 2 resimden 2.
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
  7. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Hard Drive: adım 7, 2 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Hard Drive: adım 7, 2 resimden 2.
    • Unscrew the hard drive.
    • There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
    • Carefully push the hard drive away from its port. This should not require substantial force.
    • Lift the hard drive out.
    • Some hard drives have a plastic tab, which can be lifted from to remove the hard drive.
    • Otherwise, take hold of opposite sides of the hard drive and lift the drive straight up.
  8. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Cover Removal: adım 8, 2 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Back Cover Removal: adım 8, 2 resimden 2.
    • Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
    • Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
  9. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Fan: adım 9, 3 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Fan: adım 9, 3 resimden 2. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Fan: adım 9, 3 resimden 3.
    • Remove the two 5mm screws on the fan assembly using a Phillips #0 screwdriver.
  10. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 10, 3 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 10, 3 resimden 2. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 10, 3 resimden 3.
    • Unplug the fan's connection to the motherboard.
    • Lift the fan from the laptop.
    • Use a soft cloth to clean the dust away from where the fan was.
  11. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Laptop Screen: adım 11, 3 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Laptop Screen: adım 11, 3 resimden 2. Toshiba Satellite L855-S5119 Laptop Screen Replacement, Laptop Screen: adım 11, 3 resimden 3.
    • Remove the two screws in each speaker using the Phillips #0 Screwdriver.
    • Gently lift out the speakers out of the chassis.
  12. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 12, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the 3mm retention screw from the display connector.
    • Unplug and remove the display connector by pulling the connector free.
  13. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 13, 3 resimden 1. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 13, 3 resimden 2. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 13, 3 resimden 3.
    • Remove the screen by removing two screws from both hinges using the #0 Phillips screwdriver.
    • Once the hinges have been unscrewed separate the screen from the body containing the motherboard.
  14. Toshiba Satellite L855-S5119 Laptop Screen Replacement: adım 14, 1 resimden 1.
    • The removed laptop screen should have the daughterboard and speakers attached to it via wires upon removal.
Sonuç
Monte Roden
465 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 665
