Ana içeriğe geç
Toshiba Satellite M305D-S4829 Motherboard Replacement
Michael Jensen
Michael Jensen ve 7 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
15 - 30 dakika
Zor
Neye ihtiyacın var
Aletler
  1. Toshiba Satellite M305D-S4829 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 2, 1 resimden 1.
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Motherboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 4, 2 resimden 2.
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 5, 2 resimden 2.
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 6, 2 resimden 2.
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 7, 2 resimden 1. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 7, 2 resimden 2.
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 8, 1 resimden 1.
    • Your keyboard has now been successfully removed.
  9. Toshiba Satellite M305D-S4829 Motherboard Replacement, CD/DVD Drive: adım 9, 1 resimden 1.
    • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  10. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 10, 2 resimden 1. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 10, 2 resimden 2.
    • Locate and remove the circled screw with a Phillips #0 screwdriver.
  11. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 11, 1 resimden 1.
    • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
  12. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 12, 1 resimden 1.
    • Gently remove the CD/DVD drive from the laptop body.
  13. Toshiba Satellite M305D-S4829 Motherboard Replacement, also remove these two screws: adım 13, 2 resimden 1. Toshiba Satellite M305D-S4829 Motherboard Replacement, also remove these two screws: adım 13, 2 resimden 2.
    • Remove the circled screws with Phillips #0 screwdriver.
  14. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove these screws from the underside of the laptop with Phillips #0 screwdriver.
  15. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 15, 1 resimden 1.
    • Disconnect the three circled antennas by lightly pulling upward with your fingers. They should detach easily.
    • Note: Yours may only have two (2) antennas. Pay attention to the Orientation of the Aluminum bracket with the pads for reinstallation.
  16. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 16, 1 resimden 1.
    • Remove the circled screw with a Phillips #0 screwdriver.
  17. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 17, 1 resimden 1.
    • Detach the 3 marked cables by pulling them out with you fingers as shown.
    • This may require some force. They do not come out easily.
  18. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 18, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Detach the four blue ribbon cables carefully with tweezers. Some of the ribbons may require a flap to be raised because it secures the ribbon in.
  19. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 19, 1 resimden 1.
    • Remove the top plastic cover by lifting upward from the bottom left-hand corner as shown. The cover will come off easily.
  20. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 20, 1 resimden 1.
    • Remove the circled motherboard screws with a Phillips #0 Scewdriver.
    • Disconnect this ribbon cable.
  21. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 21, 1 resimden 1.
    • Remove these screws with a Phillips #0 screwdriver.
  22. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 22, 1 resimden 1.
    • Detach the display cable by gently pulling it out with your fingers.
  23. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 23, 2 resimden 1. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 23, 2 resimden 2.
    • Remove the motherboard from the left side by gently lifting the left side upward.
    • The boxed volume control may snag on the laptop frame when pulling the motherboard out.
  24. Toshiba Satellite M305D-S4829 Motherboard Replacement: adım 24, 1 resimden 1.
    • The motherboard has now been removed from laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Michael Jensen
425 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011 üyesi
CPSU-REGAN-S11S4G3
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 11,923
