Ana içeriğe geç
Toshiba Satellite P50W-C Fan Replacement
Sarah Fordjour
Sarah Fordjour ve 5 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
4 - 6 dakika
Kolay
This guide will show you how to replace the fan in your Toshiba satellite. The fan keeps the computer cool when running. Be careful when removing the fan because the heat sink may detach from it.
Neye ihtiyacın var
  1. Toshiba Satellite P50W-C Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Fan Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Fan Replacement: adım 3, 2 resimden 1. Toshiba Satellite P50W-C Fan Replacement: adım 3, 2 resimden 2.
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Fan Replacement, Fan: adım 4, 1 resimden 1.
    • Unscrew the two 7 mm JIS #1 head screws securing the fan to the laptop.
  5. Toshiba Satellite P50W-C Fan Replacement: adım 5, 1 resimden 1.
    • Using tweezers, disconnect power cable by gently pulling white end out from its socket.
  6. Toshiba Satellite P50W-C Fan Replacement: adım 6, 1 resimden 1.
    • Remove heat sink by unscrewing the four 3 mm JIS #1 head screws
  7. Toshiba Satellite P50W-C Fan Replacement: adım 7, 3 resimden 1. Toshiba Satellite P50W-C Fan Replacement: adım 7, 3 resimden 2. Toshiba Satellite P50W-C Fan Replacement: adım 7, 3 resimden 3.
    • Based on the quality of the fan either the clean fan or replace the fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sarah Fordjour
450 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Cannon Fall 2017 USF Tampa, Team S3-G2, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G2
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 917
