Ana içeriğe geç
Toshiba Satellite P50W-C Hard Drive Replacement
Sarah Fordjour
Sarah Fordjour ve 2 diğer katkıda bulunanlar
En son December 13, 2017 tarihinde güncellendi
4 - 7 dakika
Kolay
Be careful to handle this device with care while performing this guide make sure to use use an anti-static wrist strap.
Neye ihtiyacın var
  1. Toshiba Satellite P50W-C Hard Drive Replacement, Back Cover: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Hard Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite P50W-C Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove the back cover of the device.
  5. Toshiba Satellite P50W-C Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive from the device by gently pulling on the blue plastic hard drive cover.
  6. Toshiba Satellite P50W-C Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite P50W-C Hard Drive Replacement: adım 6, 2 resimden 2.
    • Disconnect the hard drive from the mother board by gently pulling out the black connector.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sarah Fordjour
450 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Cannon Fall 2017 USF Tampa, Team S3-G2, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G2
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
Can you change the touch panel of toshibasatelliteP50W-B1038.
rizwana rizi - Yanıt
Hi dear,
My laptop bios was crashed,
I need to radius 15 p50w-c-104 bios dump file.
can you help me please.?
labexperiance@gmail.com
thank you
Mustafa SAYIN - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 705
