Ana içeriğe geç
Toshiba Satellite P50W-C Mother Board Replacement
Brittany Edwards
Brittany Edwards ve 3 diğer katkıda bulunanlar
En son December 13, 2017 tarihinde güncellendi
25 dakika
Zor
The motherboard contains the principal components of the device. Make sure the device is not connected to any source of power before removing any parts. Clips and connections may break easily so be gentle when removing parts.
Neye ihtiyacın var
  1. Toshiba Satellite P50W-C Mother Board Replacement, Back Cover: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Mother Board Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Mother Board Replacement: adım 3, 2 resimden 1. Toshiba Satellite P50W-C Mother Board Replacement: adım 3, 2 resimden 2.
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: adım 4, 3 resimden 1. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: adım 4, 3 resimden 2. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: adım 4, 3 resimden 3.
    • Remove all power connections to the motherboard. Including the black and white power connections to the wifi module.
  5. Toshiba Satellite P50W-C Mother Board Replacement: adım 5, 3 resimden 1. Toshiba Satellite P50W-C Mother Board Replacement: adım 5, 3 resimden 2. Toshiba Satellite P50W-C Mother Board Replacement: adım 5, 3 resimden 3.
    • Unscrew the two 7 mm JIS head screws in the fan .
    • Then unscrew the four 2 mm JIS head screws connecting the heat sink to the mother board.
    • Then take out the heat sink and fan.
  6. Toshiba Satellite P50W-C Mother Board Replacement: adım 6, 1 resimden 1.
    • Remove both 3mm JIS head screws connecting the motherboard to the device.
  7. Toshiba Satellite P50W-C Mother Board Replacement: adım 7, 1 resimden 1.
    • Remove 5mm silver Phillips head screw connecting black cover to the motherboard
  8. Toshiba Satellite P50W-C Mother Board Replacement: adım 8, 2 resimden 1. Toshiba Satellite P50W-C Mother Board Replacement: adım 8, 2 resimden 2.
    • Remove all three 5 mm silver JIS head screws connecting the silver cover to the motherboard.
  9. Toshiba Satellite P50W-C Mother Board Replacement: adım 9, 1 resimden 1.
    • You can now gently remove the motherboard from the device.
Sonuç
Brittany Edwards
104 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Cannon Fall 2017 USF Tampa, Team S3-G2, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G2
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Hi dear,
My laptop bios was crashed,
I need to radius 15 p50w-c-104 bios dump file.
can you help me please.?
labexperiance@gmail.com
thank you
Mustafa SAYIN - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 510
