Ana içeriğe geç
Toshiba Satellite P50W-C Wifi Module  Replacement
Sarah Fordjour
Sarah Fordjour ve 4 diğer katkıda bulunanlar
En son December 13, 2017 tarihinde güncellendi
1 dakika
Çok kolay
The wifi module connects the device to wireless internet networks. Be careful when handling the wifi module.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite P50W-C Wifi Module  Replacement, Back Cover: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Wifi Module  Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Wifi Module  Replacement: adım 3, 2 resimden 1. Toshiba Satellite P50W-C Wifi Module  Replacement: adım 3, 2 resimden 2.
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Wifi Module  Replacement, Wifi Module: adım 4, 1 resimden 1.
    • Locate the Wi-Fi module in the device which is located next to the ram.
  5. Toshiba Satellite P50W-C Wifi Module  Replacement: adım 5, 1 resimden 1.
    • Unscrew the 3mm JIS head screw with J1#1. This screw is holding the Wi-Fi module to the device
  6. Toshiba Satellite P50W-C Wifi Module  Replacement: adım 6, 1 resimden 1.
    • Remove the black and white wires that are connected to the device by gently pulling on it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sarah Fordjour
450 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G2, Cannon Fall 2017 USF Tampa, Team S3-G2, Cannon Fall 2017 üyesi
USFT-CANNON-F17S3G2
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 637
