Ana içeriğe geç
Toshiba Satellite P55-A5312 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: adım 1, 2 resimden 2.
  2. Toshiba Satellite P55-A5312 Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite P55-A5312 Battery Replacement: adım 2, 2 resimden 2.
    • Locate the battery, which is in the top right hand corner of the laptop.
    • Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
  3. Toshiba Satellite P55-A5312 Battery Replacement: adım 3, 1 resimden 1.
    • Locate the intersection of the wires that connect the battery to the motherboard.
    • Unplug these wires by gently pulling on the white plug, as shown in the picture.
  4. Toshiba Satellite P55-A5312 Battery Replacement: adım 4, 1 resimden 1.
    • Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
    • Move the speaker elsewhere while replacing the battery (do not disconnect it).
  5. Toshiba Satellite P55-A5312 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the laptop after it has been completely disconnected.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
ohatae
294 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-1, Banghart Winter 2017 Cal Poly, Team 9-1, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S9G1
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 5,994
