Ana içeriğe geç
Toshiba Satellite P55W-C5316 Battery Replacement
Alec Bonnell
Alec Bonnell ve 3 diğer katkıda bulunanlar
En son June 22, 2020 tarihinde güncellendi
5 dakika
Kolay
This guide about removing the battery is fairly straightforward. Be careful to not yank on the connector between the battery and the laptop. Also, make sure that the laptop is turned off before attempting this guide.
Neye ihtiyacın var
Tamir Seti
Bu kit, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: adım 1, 2 resimden 1. Toshiba Satellite P55W-C5316 Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Battery Replacement: adım 2, 3 resimden 1. Toshiba Satellite P55W-C5316 Battery Replacement: adım 2, 3 resimden 2. Toshiba Satellite P55W-C5316 Battery Replacement: adım 2, 3 resimden 3.
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 Battery Replacement, Battery: adım 3, 3 resimden 1. Toshiba Satellite P55W-C5316 Battery Replacement, Battery: adım 3, 3 resimden 2. Toshiba Satellite P55W-C5316 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • The battery is located in the bottom right corner of the laptop.
    • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  4. Toshiba Satellite P55W-C5316 Battery Replacement: adım 4, 2 resimden 1. Toshiba Satellite P55W-C5316 Battery Replacement: adım 4, 2 resimden 2.
    • Do not tug on the cord or battery. Instead, pull evenly on the connector.
    • Lift the battery and gently pull out the bundled cable connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alec Bonnell
497 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 UMass Dartmouth, Team S3-G2, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G2
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Hello, please I've been searching and searching online to get motherboard for Toshiba Satellite P55W-C5316 but i don't seen to find any. Can anyone lead me to get one to buy.
Owusu Bright - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 3,076
