Ana içeriğe geç
Toshiba Satellite S55T-B5335 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite S55T-B5335 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 2, 3 resimden 1. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 2, 3 resimden 2. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 2, 3 resimden 3.
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Keyboard Replacement, Bottom Cover: adım 3, 2 resimden 1. Toshiba Satellite S55T-B5335 Keyboard Replacement, Bottom Cover: adım 3, 2 resimden 2.
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 4, 1 resimden 1.
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 5, 1 resimden 1.
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Keyboard Replacement, Cooling Fans: adım 6, 1 resimden 1.
    • Remove the two 3.5 mm Phillips #1 screws that hold the cooling fan in place.
  7. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 7, 1 resimden 1.
    • Wedge the flat end of the spudger between the connector and its socket.
    • Twist back and forth in order to pry the connector loose from its socket.
    • Although you can pull on the connector wires to remove it from the socket, it is not recommended until the connector is loose to prevent damage to the wires.
  8. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 8, 1 resimden 1.
    • Lift up on the cooling fan to remove it from the laptop.
    • Repeat steps 6-8 for the other cooling fan.
  9. Toshiba Satellite S55T-B5335 Keyboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Remove the three 4 mm Phillips #1 screws holding the motherboard in place.
  10. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 10, 2 resimden 1. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 10, 2 resimden 2.
    • Remove the four 4 mm Phillips #1 screws mounting the heat sink to the motherboard.
  11. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 11, 1 resimden 1.
    • Gently lift on either side of the heat sink to separate it from the laptop.
    • When reassembling the device, be sure to apply new thermal paste to the heat sink and processor.
  12. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 12, 2 resimden 1. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 12, 2 resimden 2.
    Bu adımda kullanılan alet:
    • On all ZIF (Zero Insertion Force) connectors, use a spudger to lift the lock.
    • Use tweezers to pull on the designated pull tab to remove each ZIF connector.
  13. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 13, 2 resimden 1. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 13, 2 resimden 2.
    • On all No-Fuss Ribbon Cable Connectors use tweezers, on the designated tabs, to remove them.
  14. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 14, 1 resimden 1.
    • Lift on the motherboard from the USB port area while pulling the frame away from motherboard.
  15. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 15, 3 resimden 1. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 15, 3 resimden 2. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 15, 3 resimden 3.
    • Once all connectors are separated from the motherboard and the USB port area is freed, carefully lift on either side of the motherboard to remove it.
  16. Toshiba Satellite S55T-B5335 Keyboard Replacement, Keyboard: adım 16, 1 resimden 1.
    • Remove the twenty-seven 2 mm Phillips #0 screws that secure the keyboard retaining plate.
  17. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 17, 2 resimden 1. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 17, 2 resimden 2.
    • Carefully lift the keyboard retaining plate away from the laptop making sure not to damage any connectors.
  18. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 18, 2 resimden 1. Toshiba Satellite S55T-B5335 Keyboard Replacement: adım 18, 2 resimden 2.
    • Lift up on the keyboard to remove it from the laptop.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
George Gillespie
721 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Blackwell Fall 2016 USF Tampa, Team 2-1, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G1
4 Üyeler
1Rehber Yorum
trying to find repair guide for Toshiba Satellite L55-A5226. Keyboard needs repacing.
macariq - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 3,935
