Ana içeriğe geç
Toshiba Satellite U925T-S2120 RAM Replacement
Andrew Honderich
Andrew Honderich ve 4 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
15 - 20 dakika
Kolay
In this guide you will learn how to remove the RAM of your Toshiba Satellite U925T-S2120. If your RAM is broken, you may need to replace it. Before beginning this guide you should have all required tools that are listed.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Toshiba Satellite U925T-S2120 RAM Replacement, RAM: adım 1, 2 resimden 1. Toshiba Satellite U925T-S2120 RAM Replacement, RAM: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the 9 rubber gripper pads on the back panel of the laptop using tweezers.
  2. Toshiba Satellite U925T-S2120 RAM Replacement: adım 2, 3 resimden 1. Toshiba Satellite U925T-S2120 RAM Replacement: adım 2, 3 resimden 2. Toshiba Satellite U925T-S2120 RAM Replacement: adım 2, 3 resimden 3.
    • Unscrew nine 5.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
    • Unscrew two 6.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
  3. Toshiba Satellite U925T-S2120 RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite U925T-S2120 RAM Replacement: adım 3, 2 resimden 2.
    • Take off the back panel open by sticking the plastic opening tool into the seam of the laptop, and pushing the opening tool downwards.
  4. Toshiba Satellite U925T-S2120 RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite U925T-S2120 RAM Replacement: adım 4, 2 resimden 2.
    • Gently pinch the RAM with your thumb and pointer finger.
    • Pull the RAM out of the logic board with gentle force.
    • Try to keep the RAM parallel as you pull it out, so that the RAM does not chip.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew Honderich
364 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S5-G5, Williams Spring 2017 Baylor, Team S5-G5, Williams Spring 2017 üyesi
BU-WILLIAMS-S17S5G5
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 592
