Ana içeriğe geç
Toshiba Satellite c650d RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite c650d RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d RAM Replacement: adım 2, 1 resimden 1.
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite c650d RAM Replacement: adım 3, 2 resimden 2.
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Remove the one 5.5mm Philips #0 screw that holds in the central panel.
  5. Toshiba Satellite c650d RAM Replacement: adım 5, 1 resimden 1.
    • Pull the back panel off.
  6. Toshiba Satellite c650d RAM Replacement: adım 6, 1 resimden 1.
    • Remove the RAM.
    • Carefully undo the clips on either side of the top RAM.
    • Remove the chip by pulling it out of its slot.
    • Repeat until you have removed the chip that you want to replace.
    • This laptop has only two slots for RAM, and both are filled. Plan accordingly if your goal is to increase RAM.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brenna Callahan
868 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 714
