Ana içeriğe geç
Toshiba Satellite e205 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite e205 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite e205 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Keyboard Replacement: adım 4, 1 resimden 1.
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler
5.031 İtibar
16 adet Kılavuz yazıldı
Ekip
TechForce TechForce üyesi
Business
2 Üyeler
29 adet Kılavuz yazıldı
2Kılavuz Yorumları
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - Yanıt
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 27
Her zaman: 711
