Giriş
The keyboard needs to be removed to access everything (hard drive, optical drive, RAM, motherboard).
Neye ihtiyacın var
With the battery away from you, slide the locking clips out.
Slide the battery away from you.
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
