Ana içeriğe geç
Toshiba Tecra Z50-A Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Tecra Z50-A Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Motherboard Replacement: adım 2, 1 resimden 1.
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Motherboard Replacement, Battery: adım 3, 1 resimden 1.
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Motherboard Replacement: adım 4, 1 resimden 1.
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Motherboard Replacement: adım 7, 1 resimden 1.
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Motherboard Replacement, CPU Fan and Heat Sink: adım 8, 1 resimden 1.
    • Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
  9. Toshiba Tecra Z50-A Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the two 4 mm screws from the fan using a Phillips #0 screwdriver.
  10. Toshiba Tecra Z50-A Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the heat sink from the laptop.
  11. Toshiba Tecra Z50-A Motherboard Replacement: adım 11, 1 resimden 1.
    • Pull towards the bottom of the laptop to disconnect the fan cable from its connector on the motherboard.
  12. Toshiba Tecra Z50-A Motherboard Replacement: adım 12, 1 resimden 1.
    • Lift up on the fan and remove it from the laptop.
    • When replacing the fan and heat sink, be sure to reapply thermal paste.
  13. Toshiba Tecra Z50-A Motherboard Replacement, Motherboard: adım 13, 1 resimden 1.
    • Remove the two 5 mm screws using a Phillips #0 screwdriver.
  14. Toshiba Tecra Z50-A Motherboard Replacement: adım 14, 1 resimden 1.
    • Remove the three 5 mm screws using a Phillips #0 screwdriver.
  15. Toshiba Tecra Z50-A Motherboard Replacement: adım 15, 1 resimden 1.
    • Lift up on plastic covering over the Wi-Fi card.
    • Disconnect the black and white coaxial cables from the Wi-Fi card.
  16. Toshiba Tecra Z50-A Motherboard Replacement: adım 16, 1 resimden 1.
    • Unplug the bundled red and black cable from its connector on the motherboard.
  17. Toshiba Tecra Z50-A Motherboard Replacement: adım 17, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift up on the black retaining flap using a pair of tweezers.
  18. Toshiba Tecra Z50-A Motherboard Replacement: adım 18, 1 resimden 1.
    • Push the tab on the right toward the top of the laptop.
  19. Toshiba Tecra Z50-A Motherboard Replacement: adım 19, 1 resimden 1.
    • Push the tab on the left toward the top of the laptop.
  20. Toshiba Tecra Z50-A Motherboard Replacement: adım 20, 1 resimden 1.
  21. Toshiba Tecra Z50-A Motherboard Replacement: adım 21, 1 resimden 1.
  22. Toshiba Tecra Z50-A Motherboard Replacement: adım 22, 1 resimden 1.
    • Lift up on the charging port with tweezers.
  23. Toshiba Tecra Z50-A Motherboard Replacement: adım 23, 1 resimden 1.
    • Lift up on the plastic tab.
  24. Toshiba Tecra Z50-A Motherboard Replacement: adım 24, 1 resimden 1.
    • Pull plug towards the bottom of the laptop.
  25. Toshiba Tecra Z50-A Motherboard Replacement: adım 25, 1 resimden 1.
    • Grab the middle of the motherboard with your hands and lift up to remove it from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Luis Juen Baez
585 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G4
3 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 828
