Ana içeriğe geç
Trek 820 Handlebars Replacement
Kaveh Karimiyanha
Kaveh Karimiyanha ve 10 diğer katkıda bulunanlar
En son November 13, 2020 tarihinde güncellendi
5 dakika
Kolay
İşlem Görüntüleri
Use this guide to remove the handlebar and stem from a Trek 820 or similar bikes that have a thread less stem.
The stem acts with the handlebar to steer the bike in the desired location while keeping the fork and headset attached to the bikes frame. It is important that these steps are done correctly to ensure that the rider is safe while operating this bicycle.
Before using this guide make sure you have the correct size handlebar and stem depending on which item you are replacing.
Neye ihtiyacın var
  1. Trek 820 Handlebars Replacement, Handlebar and stem: adım 1, 2 resimden 1. Trek 820 Handlebars Replacement, Handlebar and stem: adım 1, 2 resimden 2.
    • Use a 3/16" Allen Wrench to remove the silver cap.
  2. Trek 820 Handlebars Replacement: adım 2, 1 resimden 1.
    • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
  3. Trek 820 Handlebars Replacement: adım 3, 2 resimden 1. Trek 820 Handlebars Replacement: adım 3, 2 resimden 2.
    • Remove the handlebar by lifting vertically away from the frame.
    • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
  4. Trek 820 Handlebars Replacement: adım 4, 2 resimden 1. Trek 820 Handlebars Replacement: adım 4, 2 resimden 2.
    • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
    • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
  5. Trek 820 Handlebars Replacement: adım 5, 1 resimden 1.
    • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
    • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
    • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
Sonuç
Kaveh Karimiyanha
813 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G1
5 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 26
Her zaman: 5,988
