Ana içeriğe geç
Trio Stealth G4 Motherboard Replacement
Neye ihtiyacın var
  1. Trio Stealth G4 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Be sure to shut down and unplug your device before you begin.
    • Flip your tablet over so that the back panel is facing up.
  2. Trio Stealth G4 Motherboard Replacement: adım 2, 2 resimden 1. Trio Stealth G4 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to gently pry the back panel assembly apart from the front casing.
    • Start on one edge of the device by inserting the plastic opening tool between the back panel and the front casing using a gentle rocking motion.
  3. Trio Stealth G4 Motherboard Replacement: adım 3, 1 resimden 1.
    • Once you have successfully separated one edge of the back panel from the front casing, slide the plastic opening tool along the other edges to detach them as well.
    • The latches keeping the back panel attached to the front casing can sometimes be a little difficult to separate, so don't be afraid to use some force.
  4. Trio Stealth G4 Motherboard Replacement: adım 4, 2 resimden 1. Trio Stealth G4 Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the back panel from the rest of the tablet and set it aside.
  5. Trio Stealth G4 Motherboard Replacement: adım 5, 1 resimden 1.
    • The plastic volume button cover may fall out when you remove the back panel. Set it aside.
  6. Trio Stealth G4 Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Trio Stealth G4 Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Trio Stealth G4 Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove the 4 pieces of tape covering the zero insertion force (ZIF) connectors on the motherboard.
  7. Trio Stealth G4 Motherboard Replacement: adım 7, 3 resimden 1. Trio Stealth G4 Motherboard Replacement: adım 7, 3 resimden 2. Trio Stealth G4 Motherboard Replacement: adım 7, 3 resimden 3.
    • Use a spudger to flip up the black flaps on each of the 4 ZIF connectors.
    • Once the flaps are up, use your fingers to disconnect the end of the ribbon wires from the connectors.
  8. Trio Stealth G4 Motherboard Replacement: adım 8, 2 resimden 1. Trio Stealth G4 Motherboard Replacement: adım 8, 2 resimden 2.
    • Use the soldering iron to melt away the solder from each of the wires connecting to the motherboard.
    • Once the solder is completely removed, pull the wires away from the motherboard.
  9. Trio Stealth G4 Motherboard Replacement: adım 9, 2 resimden 1. Trio Stealth G4 Motherboard Replacement: adım 9, 2 resimden 2.
    • Use a J00 Phillips head screwdriver to remove the two 4.3 mm screws securing the motherboard to the device and set them aside.
  10. Trio Stealth G4 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the silver piece of tape from the left edge of the motherboard.
  11. Trio Stealth G4 Motherboard Replacement: adım 11, 2 resimden 1. Trio Stealth G4 Motherboard Replacement: adım 11, 2 resimden 2.
    • Use a spudger to lift the motherboard from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matt Arnold
607 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-1, Williams Fall 2015 Baylor, Team 4-1, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S4G1
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 900
