Giriş
If the battery on your Trio Stealth-10 is no longer functioning, replacement isn't difficult and this guide will give you the step by step procedure to do so.
Neye ihtiyacın var
To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
Bu adımda kullanılan alet:Tweezers$4.99
Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
Pull the cable away and clear from under the battery to avoid damage to the connection.
6 farklı kişi bu kılavuzu tamamladı.
