Ana içeriğe geç
Trio Stealth-10 Speaker Replacement
Neye ihtiyacın var
  1. Trio Stealth-10 Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Speaker Replacement, Speaker: adım 2, 1 resimden 1.
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  3. Trio Stealth-10 Speaker Replacement: adım 3, 1 resimden 1.
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Coleman
643 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Miles Fall 2015 UMass Dartmouth, Team 1-4, Miles Fall 2015 üyesi
UMASSD-MILES-F15S1G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 287
