Ana içeriğe geç
Turtle Beach Ear Force P11 Microphone Replacement
Neye ihtiyacın var
  1. Turtle Beach Ear Force P11 Microphone Replacement, Microphone: adım 1, 1 resimden 1.
    • Remove the microphone cover by unscrewing the screw on the front side of the microphone.
    • It is recommended to use #000 Philips head screwdriver.
  2. Turtle Beach Ear Force P11 Microphone Replacement: adım 2, 1 resimden 1.
    • Use a nylon or metal spudger set to lift out the microphone.
    • Be careful lest you might break the fragile wires.
    • Always try using a plastic tool before resorting to a metal tool as shown in the picture.
  3. Turtle Beach Ear Force P11 Microphone Replacement: adım 3, 1 resimden 1.
    • De-solder the microphone wires and remove the microphone.
    • Use low heat for de - soldering
    • Do not cut the white and black wires soldered to the microphone as you might reduce the length of wire required to reassemble.
  4. Turtle Beach Ear Force P11 Microphone Replacement: adım 4, 1 resimden 1.
    • Solder the new microphone wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • You can find more information on How to Solder here: How To Solder and Desolder Connections
    • To complete reassembly replace the cover taken off in step 1.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bhavesh Gandhi
585 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Wilson Fall 2015 IUPUI, Team 1-2, Wilson Fall 2015 üyesi
IUPUI-WILSON-F15S1G2
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,029
