Ana içeriğe geç
Turtle Beach Ear Force XO Four Speaker Cone Replacement
Neye ihtiyacın var
  1. Turtle Beach Ear Force XO Four Speaker Cone Replacement, Ear Cushion: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    Satın Al
    • Insert a flat metal object (such as iFixit's Jimmy tool) between the green and black plastic portions of the headset.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. Turtle Beach Ear Force XO Four Speaker Cone Replacement: adım 2, 2 resimden 1. Turtle Beach Ear Force XO Four Speaker Cone Replacement: adım 2, 2 resimden 2.
    • Carefully pry the plastic pieces apart, working your way around the ear cushion.
    • Be sure not to break the tabs on the back side of the ear pad!
  3. Turtle Beach Ear Force XO Four Speaker Cone Replacement: adım 3, 3 resimden 1. Turtle Beach Ear Force XO Four Speaker Cone Replacement: adım 3, 3 resimden 2. Turtle Beach Ear Force XO Four Speaker Cone Replacement: adım 3, 3 resimden 3.
    • Pull the loosened ear pad apart from the rest of the speaker.
    • Pushing the pad and the speaker back together is the only step required for ear pad reassembly.
  4. Turtle Beach Ear Force XO Four Speaker Cone Replacement, Speaker Cone: adım 4, 2 resimden 1. Turtle Beach Ear Force XO Four Speaker Cone Replacement, Speaker Cone: adım 4, 2 resimden 2.
    • Remove four 7.3mm PH0 screws.
    • As these screws are very small, it may be best to keep them in a plastic bag or other container.
  5. Turtle Beach Ear Force XO Four Speaker Cone Replacement: adım 5, 2 resimden 1. Turtle Beach Ear Force XO Four Speaker Cone Replacement: adım 5, 2 resimden 2.
    • Lift speaker cone off of the back casing.
    • Be gentle; the small wires connecting the speaker cone to the rest of the device may break if you pull too hard.
    • Follow iFixit's soldering guide to remove the wires connected to the speaker.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Evalyn Johnson
228 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 10-14, Williams Fall 2015 Baylor, Team 10-14, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S10G14
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 9,384
