Ana içeriğe geç
Turtle Beach Elite 800 Audio Board Replacement
Neye ihtiyacın var
  1. Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: adım 1, 2 resimden 1. Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: adım 1, 2 resimden 2.
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Audio Board Replacement, Audio Board: adım 2, 2 resimden 1. Turtle Beach Elite 800 Audio Board Replacement, Audio Board: adım 2, 2 resimden 2.
    • Remove the screws (9.47 mm Phillips head) from the blue plating on the headset to reveal the inside.
  3. Turtle Beach Elite 800 Audio Board Replacement: adım 3, 2 resimden 1. Turtle Beach Elite 800 Audio Board Replacement: adım 3, 2 resimden 2.
    • If you are working on the LEFT side ear, you will first have to detach the battery by gently unplugging the white plug on the top of the board.
    • Make sure when unplugging the battery to not pull the manilla colored part which is attached to the board, but the white plug instead.
    • If you are working on the RIGHT side ear, you will first have to remove the charging contacts (2 7.92 mm Phillips screws).
  4. Turtle Beach Elite 800 Audio Board Replacement: adım 4, 3 resimden 1. Turtle Beach Elite 800 Audio Board Replacement: adım 4, 3 resimden 2. Turtle Beach Elite 800 Audio Board Replacement: adım 4, 3 resimden 3.
    • Desolder the necessary wires. (Each side will be slightly different.)
    • Be careful when using a soldering iron. Refer to the desoldering guide for tips.
    • For the purpose of this guide we clipped the wires connected to the board.
    • Remove the 4 screws (7.71mm Phillips head) using the #0 screw bit, that are holding the board in place.
    • Finally, remove the audio board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 1,908
