Ana içeriğe geç
Turtle Beach Recon 70P Microphone Replacement
Neye ihtiyacın var
  1. Turtle Beach Recon 70P Microphone Replacement, Microphone: adım 1, 2 resimden 1. Turtle Beach Recon 70P Microphone Replacement, Microphone: adım 1, 2 resimden 2.
    • Before continuing, remove the left ear pad with the earpad replacement guide.
    • Ensure that you are removing the side that houses the microphone.
    • Use a spudger to pry up the black plastic housing.
    • Remove the plastic cover.
  2. Turtle Beach Recon 70P Microphone Replacement: adım 2, 3 resimden 1. Turtle Beach Recon 70P Microphone Replacement: adım 2, 3 resimden 2. Turtle Beach Recon 70P Microphone Replacement: adım 2, 3 resimden 3.
    • Use a Phillips screwdriver remove the two 5 mm screws that secure the motherboard.
  3. Turtle Beach Recon 70P Microphone Replacement: adım 3, 3 resimden 1. Turtle Beach Recon 70P Microphone Replacement: adım 3, 3 resimden 2. Turtle Beach Recon 70P Microphone Replacement: adım 3, 3 resimden 3.
    • Use a Phillips screwdriver to remove the single 8 mm screw under the motherboard that secures the microphone.
  4. Turtle Beach Recon 70P Microphone Replacement: adım 4, 3 resimden 1. Turtle Beach Recon 70P Microphone Replacement: adım 4, 3 resimden 2. Turtle Beach Recon 70P Microphone Replacement: adım 4, 3 resimden 3.
    • You may need to move the wire connecting to the speaker to easily remove the motherboard.
    • Remove the circuit board from the housing.
    • Take care not to strain the wires.
  5. Turtle Beach Recon 70P Microphone Replacement: adım 5, 1 resimden 1.
    • Desolder the microphone connections.
    • Soldering irons can cause burns and fires. Always solder and desolder in a well-ventilated workspace.
Sonuç
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 265
