Ana içeriğe geç
Turtle Beach Recon 70P Motherboard Replacement
Neye ihtiyacın var
  1. Turtle Beach Recon 70P Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Turtle Beach Recon 70P Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Turtle Beach Recon 70P Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove the left ear pad by following the steps from the ear pad replacement guide.
    • Use a spudger to pry up and remove the black plastic cover.
  2. Turtle Beach Recon 70P Motherboard Replacement: adım 2, 3 resimden 1. Turtle Beach Recon 70P Motherboard Replacement: adım 2, 3 resimden 2. Turtle Beach Recon 70P Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two 5 mm screws that secure the motherboard.
  3. Turtle Beach Recon 70P Motherboard Replacement: adım 3, 3 resimden 1. Turtle Beach Recon 70P Motherboard Replacement: adım 3, 3 resimden 2. Turtle Beach Recon 70P Motherboard Replacement: adım 3, 3 resimden 3.
    • You may need to move the speaker so it does not block the path of the motherboard.
    • Remove the motherboard from the headset by up and away from the volume wheel.
    • Take care not to strain the connections.
  4. Turtle Beach Recon 70P Motherboard Replacement: adım 4, 2 resimden 1. Turtle Beach Recon 70P Motherboard Replacement: adım 4, 2 resimden 2.
    • Before replacing the motherboard, use flush cutters to cut each wire connected to the motherboard.
    • Cut the wires as close as possible to their connections.
    • Take note of how each component connects to the motherboard.
  5. Turtle Beach Recon 70P Motherboard Replacement: adım 5, 2 resimden 1. Turtle Beach Recon 70P Motherboard Replacement: adım 5, 2 resimden 2.
    • Prepare your replacement motherboard before continuing.
    • Solder each wire of the new motherboard in the same spots they were originally found.
    • Soldering irons can cause burns, fires and device damage. Always solder in a well-ventilated area.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 135
