Ana içeriğe geç
Turtle Beach Recon 70P Talkback Cable Replacement
Neye ihtiyacın var
    1. Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: adım 1, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: adım 1, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: adım 1, 3 resimden 3.
      • Remove the left ear pad by following the steps from the ear pad replacement guide. earpad replacement guide.
      • Use a spudger to pry up and remove the black plastic cover.
      FixBot'a Sor
      Yorum Ekle
    2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 2, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 2, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 2, 3 resimden 3.
      • Use a Phillips screwdriver to remove the two 5 mm screws that secure the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Turtle Beach Recon 70P Talkback Cable Replacement: adım 3, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 3, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 3, 3 resimden 3.
      • Cut the talkback cable below where it enters the speaker housing.
      • Remove the cut section of the talkback cable.
      FixBot'a Sor
      Yorum Ekle
    4. Turtle Beach Recon 70P Talkback Cable Replacement: adım 4, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 4, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 4, 3 resimden 3.
      • You may need to move the speaker wire out of site so it will not block the motherboard.
      • Lift the motherboard up and out of the housing.
      • Take care not to strain the wires.
      FixBot'a Sor
      Yorum Ekle
    5. Turtle Beach Recon 70P Talkback Cable Replacement: adım 5, 2 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 5, 2 resimden 2.
      • Desolder all of the talkback cable motherboard connections.
      FixBot'a Sor
      Yorum Ekle
    6. Turtle Beach Recon 70P Talkback Cable Replacement: adım 6, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 6, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 6, 3 resimden 3.
      • Feed the replacement talkback cable through the housing, then solder every wire onto the motherboard's connection points in the order they were initially found.
      • The purpose of each wire is designated in small text on the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Thanks for the run down but could you please share what cable you used to replaced old one with? is it just 3.5mm jack, four pole extension cable which you stripped on one side ?
Bartosz Debski - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 47
Her zaman: 990
