Ana içeriğe geç
Turtle Beach Recon 70P Talkback Cable Replacement
Neye ihtiyacın var
  1. Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: adım 1, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: adım 1, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement, Talkback Cable: adım 1, 3 resimden 3.
    • Remove the left ear pad by following the steps from the ear pad replacement guide. earpad replacement guide.
    • Use a spudger to pry up and remove the black plastic cover.
  2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 2, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 2, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 2, 3 resimden 3.
    • Use a Phillips screwdriver to remove the two 5 mm screws that secure the motherboard.
  3. Turtle Beach Recon 70P Talkback Cable Replacement: adım 3, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 3, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 3, 3 resimden 3.
    • Cut the talkback cable below where it enters the speaker housing.
    • Remove the cut section of the talkback cable.
  4. Turtle Beach Recon 70P Talkback Cable Replacement: adım 4, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 4, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 4, 3 resimden 3.
    • You may need to move the speaker wire out of site so it will not block the motherboard.
    • Lift the motherboard up and out of the housing.
    • Take care not to strain the wires.
  5. Turtle Beach Recon 70P Talkback Cable Replacement: adım 5, 2 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 5, 2 resimden 2.
    • Desolder all of the talkback cable motherboard connections.
  6. Turtle Beach Recon 70P Talkback Cable Replacement: adım 6, 3 resimden 1. Turtle Beach Recon 70P Talkback Cable Replacement: adım 6, 3 resimden 2. Turtle Beach Recon 70P Talkback Cable Replacement: adım 6, 3 resimden 3.
    • Feed the replacement talkback cable through the housing, then solder every wire onto the motherboard's connection points in the order they were initially found.
    • The purpose of each wire is designated in small text on the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 351
