Ana içeriğe geç
Uniden Guardian G955 Touchscreen Replacement
Neye ihtiyacın var
  1. Uniden Guardian G955 Touchscreen Replacement, Touchscreen: adım 1, 1 resimden 1.
    • Use a J1 Phillips screwdriver to remove the four 6.1 mm screws at the back of the monitor.
  2. Uniden Guardian G955 Touchscreen Replacement: adım 2, 1 resimden 1.
    • Use metal spudger or an opening tool to pry open the device.
  3. Uniden Guardian G955 Touchscreen Replacement: adım 3, 2 resimden 1. Uniden Guardian G955 Touchscreen Replacement: adım 3, 2 resimden 2.
    • In both pictures, disconnect the zero insertion force (ZIF) connector from the motherboard using your fingernail by sliding up on the male end of the connector to loosen it.
  4. Uniden Guardian G955 Touchscreen Replacement: adım 4, 1 resimden 1.
    • Use a J1 Phillips screwdriver to remove the two 6.1 mm screws.
  5. Uniden Guardian G955 Touchscreen Replacement: adım 5, 2 resimden 1. Uniden Guardian G955 Touchscreen Replacement: adım 5, 2 resimden 2.
    • Apply pressure to metal casing and slide off.
  6. Uniden Guardian G955 Touchscreen Replacement: adım 6, 2 resimden 1. Uniden Guardian G955 Touchscreen Replacement: adım 6, 2 resimden 2.
    • Push touchscreen through black case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Pauline Lara
301 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Nance Fall 2016 USF Tampa, Team 1-1, Nance Fall 2016 üyesi
USFT-NANCE-F16S1G1
3 Üyeler
8 adet Kılavuz yazıldı
3Kılavuz Yorumları
would the steps be the same for the g755 screen?
CLAY WILLIAMS - Yanıt
Would steps be the same for the G755?
Where do u buy the screen?
Ian - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 1,115
