Ana içeriğe geç
VTech Baby's Learning Laptop LEDs Replacement
Neye ihtiyacın var
  1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: adım 1, 1 resimden 1.
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
    FixBot'a Sor
    Yorum Ekle
  2. VTech Baby's Learning Laptop LEDs Replacement: adım 2, 1 resimden 1.
    • Remove the battery door.
    • Take out the batteries.
    FixBot'a Sor
    Yorum Ekle
  3. VTech Baby's Learning Laptop LEDs Replacement: adım 3, 2 resimden 1. VTech Baby's Learning Laptop LEDs Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
    FixBot'a Sor
    Yorum Ekle
  4. VTech Baby's Learning Laptop LEDs Replacement: adım 4, 3 resimden 1. VTech Baby's Learning Laptop LEDs Replacement: adım 4, 3 resimden 2. VTech Baby's Learning Laptop LEDs Replacement: adım 4, 3 resimden 3.
    • With the lid closed, position the device such that the handle is pointing towards you.
    • Using your fingers, gently pry open the cover from the hinge.
    • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
    FixBot'a Sor
    Yorum Ekle
  5. VTech Baby's Learning Laptop LEDs Replacement: adım 5, 1 resimden 1.
    • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. VTech Baby's Learning Laptop LEDs Replacement: adım 6, 1 resimden 1.
    • Pickup the array by the opening in the center of the board.
    • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
    • Movement of the array will be limited as it is still attached to the main device board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ekip
USF Tampa, Team 12-2, Blackwell Fall 2015 USF Tampa, Team 12-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S12G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 1,542
