Ana içeriğe geç
VTech CS6719-2 Charging Wire Repair
Neye ihtiyacın var
  1. VTech CS6719-2 Charging Wire Repair, Base: adım 1, 2 resimden 1. VTech CS6719-2 Charging Wire Repair, Base: adım 1, 2 resimden 2.
    • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
    FixBot'a Sor
    Yorum Ekle
  2. VTech CS6719-2 Charging Wire Repair: adım 2, 1 resimden 1.
    • Use the spudger to separate the bottom from the top.
    • There are two clips, located top and bottom, that you have to compress with the spudger.
    FixBot'a Sor
    Yorum Ekle
  3. VTech CS6719-2 Charging Wire Repair, Charging Wire: adım 3, 1 resimden 1.
    • Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
    FixBot'a Sor
    Yorum Ekle
  4. VTech CS6719-2 Charging Wire Repair: adım 4, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  5. VTech CS6719-2 Charging Wire Repair: adım 5, 1 resimden 1.
    • Heat up solder joint on the base unit where the charging wires are connected.
    FixBot'a Sor
    Yorum Ekle
  6. VTech CS6719-2 Charging Wire Repair: adım 6, 1 resimden 1.
    • Take a wire of solder and apply to joint on board to remove the extra solder.
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very hot.
    • Remove charging wire connection.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josh Showalter
442 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Baechle Spring 2016 IUPUI, Team 1-4, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S1G4
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 1,698
