Ana içeriğe geç
VTech CS6719-2 Speaker Replacement
Neye ihtiyacın var
  1. VTech CS6719-2 Speaker Replacement, Battery: adım 1, 2 resimden 1. VTech CS6719-2 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Speaker Replacement: adım 2, 1 resimden 1.
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Speaker Replacement: adım 3, 1 resimden 1.
    • Unplug the battery input cable.
  4. VTech CS6719-2 Speaker Replacement: adım 4, 1 resimden 1.
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Speaker Replacement, Circuit Board: adım 5, 2 resimden 1. VTech CS6719-2 Speaker Replacement, Circuit Board: adım 5, 2 resimden 2.
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Speaker Replacement: adım 6, 1 resimden 1.
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Speaker Replacement: adım 7, 2 resimden 1. VTech CS6719-2 Speaker Replacement: adım 7, 2 resimden 2.
    • Remove the two 9mm screws located inside the back cover at the top.
  8. VTech CS6719-2 Speaker Replacement, Speaker: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
    • The clip is loose, it could fall out.
  9. VTech CS6719-2 Speaker Replacement: adım 9, 1 resimden 1.
    • Lift speaker out.
  10. VTech CS6719-2 Speaker Replacement: adım 10, 1 resimden 1.
    • Heat up solder joint on the circuit board where the speaker wires are connected.
  11. VTech CS6719-2 Speaker Replacement: adım 11, 1 resimden 1.
Sonuç
Benjamin Field
270 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Baechle Spring 2016 IUPUI, Team 1-4, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S1G4
4 Üyeler
16 adet Kılavuz yazıldı
2Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 22
Her zaman: 1,046
