Ana içeriğe geç
VTech InnoTab 2S Motherboard Removal
Neye ihtiyacın var
  1. VTech InnoTab 2S Motherboard Removal, Back Panel: adım 1, 1 resimden 1.
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2S Motherboard Removal: adım 2, 2 resimden 1. VTech InnoTab 2S Motherboard Removal: adım 2, 2 resimden 2.
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2S Motherboard Removal: adım 3, 3 resimden 1. VTech InnoTab 2S Motherboard Removal: adım 3, 3 resimden 2. VTech InnoTab 2S Motherboard Removal: adım 3, 3 resimden 3.
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2S Motherboard Removal: adım 4, 2 resimden 1. VTech InnoTab 2S Motherboard Removal: adım 4, 2 resimden 2.
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2S Motherboard Removal: adım 5, 2 resimden 1. VTech InnoTab 2S Motherboard Removal: adım 5, 2 resimden 2.
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2S Motherboard Removal, Motherboard: adım 6, 1 resimden 1.
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2S Motherboard Removal: adım 7, 1 resimden 1.
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2S Motherboard Removal: adım 8, 1 resimden 1.
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2S Motherboard Removal: adım 9, 1 resimden 1.
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2S Motherboard Removal: adım 10, 1 resimden 1.
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
Bitiş Çizgisi
Ricardo Espinosa
221 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016 üyesi
USFT-LACY-F16S5G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 251
