Ana içeriğe geç
VTech InnoTab 2s Screen Replacement
Neye ihtiyacın var
    1. VTech InnoTab 2s Screen Replacement, Back Panel: adım 1, 1 resimden 1.
      • Turn your device to where the back panel is facing you.
      FixBot'a Sor
      Yorum Ekle
    2. VTech InnoTab 2s Screen Replacement: adım 2, 2 resimden 1. VTech InnoTab 2s Screen Replacement: adım 2, 2 resimden 2.
      • Lift the Leg all the way up and twist the bottom to remove.
      • Once the bottom part pops out the whole leg should just come off.
      • Remove any game cartridge from the device.
      FixBot'a Sor
      Yorum Ekle
    3. VTech InnoTab 2s Screen Replacement: adım 3, 3 resimden 1. VTech InnoTab 2s Screen Replacement: adım 3, 3 resimden 2. VTech InnoTab 2s Screen Replacement: adım 3, 3 resimden 3.
      • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
      • These covers are made of hard plastic so they may be difficult to remove.
      • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
      FixBot'a Sor
      Yorum Ekle
    4. VTech InnoTab 2s Screen Replacement: adım 4, 2 resimden 1. VTech InnoTab 2s Screen Replacement: adım 4, 2 resimden 2.
      • Remove all nine screws from the back of the device using a J0 bit.
      • Remove the small battery.
      FixBot'a Sor
      Yorum Ekle
    5. VTech InnoTab 2s Screen Replacement: adım 5, 2 resimden 1. VTech InnoTab 2s Screen Replacement: adım 5, 2 resimden 2.
      • Using a plastic opening tool, detach the backplate from the front piece.
      • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
      • Once the backplate has been removed, you will have access to the circuit board.
      FixBot'a Sor
      Yorum Ekle
    1. VTech InnoTab 2s Screen Replacement, Motherboard: adım 6, 1 resimden 1.
      • First begin by removing the three cross-head screws using a J0 bit.
      FixBot'a Sor
      Yorum Ekle
    2. VTech InnoTab 2s Screen Replacement: adım 7, 1 resimden 1.
      • First remove the ribbon cables. There are two highlighted by the red squares
      • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
      FixBot'a Sor
      Yorum Ekle
    3. VTech InnoTab 2s Screen Replacement: adım 8, 1 resimden 1.
      • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
      FixBot'a Sor
      Yorum Ekle
    4. VTech InnoTab 2s Screen Replacement: adım 9, 1 resimden 1.
      • Remove the board from the main assembly.
      • Be careful not to pull too hard so that the cables aren't broken.
      FixBot'a Sor
      Yorum Ekle
    5. VTech InnoTab 2s Screen Replacement: adım 10, 1 resimden 1.
      • De-solder the points shown to fully remove the cables and free the board.
      • A soldering guide offered by IFIXIT can be found here Soldering Skills.
      FixBot'a Sor
      Yorum Ekle
    1. VTech InnoTab 2s Screen Replacement, Screen: adım 11, 2 resimden 1. VTech InnoTab 2s Screen Replacement, Screen: adım 11, 2 resimden 2.
      • After removing the back plate and screws, all screws have been removed to separate the circuit board and wires from the front panel.
      • Remove the front panel from the device to expose the screen.
      FixBot'a Sor
      Yorum Ekle
    2. VTech InnoTab 2s Screen Replacement: adım 12, 1 resimden 1.
      • Using a heat gun, heat the glue that holds the screen to the rest of the device.
      • While heating, carefully pull screen from the device exposing the ribbon wire on the back of the screen, disconnect.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Esthevan Romeiro
261 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Lacy Fall 2016 USF Tampa, Team 5-1, Lacy Fall 2016 üyesi
USFT-LACY-F16S5G1
4 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 1,181
