Ana içeriğe geç
VTech Learning Tunes Karaoke Speaker Replacement
Neye ihtiyacın var
    1. VTech Learning Tunes Karaoke Speaker  Replacement, Speaker: adım 1, 1 resimden 1.
      • To remove the battery door, loosen the screw using a Flathead screwdriver.
      • A coin can also be used to loosen the screw.
      FixBot'a Sor
      Yorum Ekle
    2. VTech Learning Tunes Karaoke Speaker  Replacement: adım 2, 2 resimden 1. VTech Learning Tunes Karaoke Speaker  Replacement: adım 2, 2 resimden 2.
      • Remove the battery door and take out the batteries.
      FixBot'a Sor
      Yorum Ekle
    3. VTech Learning Tunes Karaoke Speaker  Replacement: adım 3, 1 resimden 1.
      • Remove the six 9.5 mm Phillips #2 screws.
      • Remove the six 6.0 mm Phillips #2 screws.
      FixBot'a Sor
      Yorum Ekle
    4. VTech Learning Tunes Karaoke Speaker  Replacement: adım 4, 2 resimden 1. VTech Learning Tunes Karaoke Speaker  Replacement: adım 4, 2 resimden 2.
      • Gently pull up on the rear panel.
      • Be careful to not pull on the wire connections.
      • Carefully place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    5. VTech Learning Tunes Karaoke Speaker  Replacement: adım 5, 2 resimden 1. VTech Learning Tunes Karaoke Speaker  Replacement: adım 5, 2 resimden 2.
      • Remove two 7.9 mm Phillips #1 screws on the speaker cover.
      • After removing the screws, remove the black plastic speaker cover to expose the speaker.
      FixBot'a Sor
      Yorum Ekle
    6. VTech Learning Tunes Karaoke Speaker  Replacement: adım 6, 1 resimden 1.
      • Desolder the speaker at the solder points to remove.
      • Learn more about soldering and desoldering connections here.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Gamuchirai Chifamba
249 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G2
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 1,098
